Android auto
I’m connect to car via Bluetooth. But when you press android auto says not compatible, I’ve a 2022 model, is the cable the issue?
Any ideas how to clear the data from previous owner if still on there, I have reset the system if that helps.
Welcome to the community, @Shellbelle74 !
Bluetooth working doesn’t necessarily mean Android Auto will work. On the 2022 DS3, Android Auto can require a USB data connection. Make sure you’re using the USB port in the dashboard that supports Android Auto, not the charging-only port in the centre console. Also try another good-quality/data-capable USB cable, preferably the original phone cable.
What kind of data is it that is left from the old owner?
I’ve reset the console and tried various usb cables directly plugged into usb connection, frustratingly quite a few times to no avail, still says not compatible, it won’t even connect wireless as it says can be done
Let’s hope someone with a DS3 and Android turns up and gives us a little more specific details for what’s required for your current setup.
Wireless Android Auto is only available on the IVI system; it requires active Wi-Fi and a Bluetooth connection. If you have an older NAC unit, Android Auto works only via USB cable—wireless is not supported.
I had the same issue with connecting via USB on my DS7 but eventually found a cable that works.
Go for a quality cable and you should be ok.
I’m sorted now thanks all
