Doesnt work in electric mode
Hi, so I use the car daily, I noticed the fuel consumtion goes up, now the car randomly start reving at stop lights up to 1400rpm with no reason and full battery, even electric mode not available.
I posted here because I think I saw a post where it says this happen because of bad under armrest auxiliary battery. Anyone have any idea why my car behave like this?
Any idea how to change the auxiliary battery? with what battery and at what sequance and if needs coding? Thanks
I had that Electric Mode Temporarily Unavailable, even with a full charge and then a few cycles of driving (petrol only). I had it booked into the DS Service Centre for a diagnosis, but before I took it in the fault cleared itself after about 2-3 weeks. I didn’t do anything other than keep driving it in petrol only - I think at the time I was mainly doing short elec only journeys, with only occasional longer drives that would use petrol. So it was probably something to do with the 12V batteries getting into a poor state.
Some people on here trickle charge their 12V batteries to avoid such problems. I don’t, as my drives have changed to mostly be longer journeys were the petrol engine will be used for part of the journey. I’ve not changed the aux battery in armrest or the bigger one under the bonnet - but I do check voltages to try to spot anything bad happening.
Hi! Just to add another possible explanation besides the 12V batteries, I found something interesting in the official DS 4 owner’s manual (page 107, Electric mode section).
It mentions that if the petrol engine starts multiple times without reaching a sufficient operating temperature, fuel can gradually dilute the engine oil. As a protective measure, the car may temporarily disable Electric mode and display the message “Electric mode unavailable: automatic operation in progress” . According to the manual, normal electric operation can be restored after approximately 50 miles (80 km) of motorway driving or 125 miles (200 km) of urban driving .
Are most of your journeys relatively short, mainly in Electric mode, with the petrol engine only starting occasionally and not running long enough to warm up properly? Also, do you get the specific “automatic operation in progress” message, or just the generic “Electric mode temporarily unavailable” warning?
As some of you may recall, I drive in electric mode 90% of the time. The only situation in which the ICE kicks in is when I wait longer than about a one minute between unlocking the car and starting it. If I get in and drive off immediately, it always starts in electric mode.
