Hi all,
I have a DS 7 Crossback E-Tense 4x4 and I’m planning to replace the discs and pads. I’m considering a full ATE set: ATE discs plus ATE Ceramic pads.
Has anyone fitted these pads, ideally on a hybrid or another heavy car with a similar brake setup? What’s your experience with them in daily use?
Or would it be better to go with Brembo instead of ATE? If anyone runs Brembo on this car or a similar one, I’d love to hear how they compare.
Any feedback is welcome, including negative experiences.
Thanks!
ATE Ceramic is a type of brake pad that produces less dust than standard ATE sets. The only benefit is having cleaner rims; otherwise, there are only downsides. I used them once (set ate+ate) and will never buy them again—they perform poorly at speeds above 100 km/h.
Brembo brakes are budget-tier and subpar, so they aren’t worth buying.
If you want to make a good choice, look into ATE—the standard version set. Another option is a Zimmermann set.
Thanks for the useful advice and for sharing your firsthand experience with ATE Ceramic.
One more question: have you ever used Yurid brake pads? If so, what was your experience with them compared to the standard ATE set?
Thanks!
I haven’t used Jurid, so I don’t have an opinion on them.
I once used EBC Red Stuff pads with drilled brake discs and was satisfied. They weren’t even noisy.
The idea of having clean wheels is tempting, but I’ll probably stick with braking performance and go for the standard ATE pads.
