DS3 E-Tense Gear oil change
Hi, everyone! I’d like to change the oil in the transmission. I can’t find the fill level anywhere. Has anyone changed it before? Or does anyone have access to the repair manual? Thanks.
There is a dual oil drain plug on the underside of the transmission; the oil level is checked via this plug. However, the best method is to drain the oil and then refill it with the exact same amount—provided, of course, that there are no leaks. The oil filler is located on top of the transmission, and the required oil type is AW-2. Unfortunately, I do not have a manual.
I’d like to buy the oil first. If I order it now, I’ll have to wait two days for it to arrive. That’s why the quantity is important to me.
PSA B71 2316 I found this standard PSA B71 2316 (75W) oil listed in the specifications everywhere.
Sorry, I mixed up the gearboxes. The AW-2 is for the eAXN8 and the 1.6 engine. Unfortunately, I don’t know the transmission fluid type for the 1.2 E-Tense.
For sure search by OE number PSA 1693483780. It’s for eDCT automatic transmission. It’s relatively inexpensive (~25EUR/1L), so for peace of mind, you can buy it at the DS Store.
It,s probably ok but I’m not sure.
Changing oil on modern gearboxes should only be done once you are 100% confident of the how. I don’t know what gearbox you have, but the Stellantis ones I’m familiar with, you do while the engine is running!
As I said, I don’t know your gearbox, but the ones I’m familiar with you can’t completely drain the oil you basically do a gradual refresh. The last one I done took 9 litres of oil to get a reasonable colour of oil in the gearbox.
Basic proceedure:- Drain, refill, and repeat (many times), with engine running. You will also need to be able to reset the oil counter.
The 1.2 MHEV is paired only with an “eDCT” automatic transmission.
I just watched the method on changing the oil of a EDCT box fitted to a Renault and the proceedure is more like old BorgWarner gearboxes - simples
Unlike changing the oil in the Asin boxes fitted to larger engined Stellantis, Volvo, Ford and other vehicles.
There are two drain plugs on the underside, but unfortunately, I don’t know the replacement procedure.
