Hi everyone,
I’m stuck with a DPF problem on my DS7 1.5 and hoping someone has come across it before.
Background
A local garage replaced the DPF at about 70k miles, using an OEM-spec part rather than a budget one. Everything was fine for around 5 days of short journeys, then a general engine fault came up with a “repair needed” warning.
What I’ve found
I bought an OBD2 reader and Diagbox v9 to investigate. My theory is that the ECU was never told the filter had been swapped, because the exhaust data is still tied to the old DPF (110,392 km) and the numbers look corrupted:
- Total soot weight: 370.055 g (should be under roughly 40-50 g)
- Cinders clogging rate: 6,150.003% (impossible, as it should max out at 100%)
- Differential pressure at idle: 38 mbar (a new filter should be under 10 mbar)
- Exhaust temperatures: 71°C / 74°C (look normal, so those sensors seem fine)
Where I’m stuck
In Diagbox, I went to:
CMM_MD1CS003_EURO6_4 → Repair → Replacement Parts → Work on the Emission Control Circuit → Replacement of the Particle Filter Differential Pressure Sensor
The operation refuses to start and gives an “outside of range” error.
Question
Is there a way to get past this, or another route to reset the DPF values? An AI tool suggested the error is caused by the high pressure reading, and that unplugging the sensor would make the ECU see 0 mbar. I’d like a second opinion before touching anything.
Any advice would be appreciated. Thanks!
