Any suggestions?
Hello from greece my name is yuval and i just bought ds7 300 4x4 rivollli
When i open the switch the clock is open and then immediately close by it self anyone knows why
When i drive 110-130 electric or gasoline the car is shaking i did all the wheels balance twice this week but its the same
I don’t have any ideas for you. But there is a thread Suspension Problem. Rear Bounces and Skips over Bumps. and Rear suspension issues that might be worth you looking at to see if related to what you have.
I recently had a rear puncture, got it repaired and re-balanced, however at around 70mph you could feel a vibration coming through the car so I took it back to have the new balance checked, they re-did it, however the problem was still there, so again I took it back , they re-did it, problem still there.
I decided to go elsewhere for a re-balance on the same wheel, problem SOLVED.
In short, try another tyre fitting company for your balancing .
