BEAM LIGHT problems
Hello.
I’m greg from France and i ve a problem with my DS7 225CV la première.
After a BSI update i see that the 3 rotative lights on the headlamp it’s not working anymore and the beam light as well. The Diagbox tester see a short circuit to positive on the dipped headlamp but i replaced the relay for them and no improvement. Can you help me?
Do you have any idee to solve the problem ?
Regards
Hello Greg
The rotating light issue requires an update to the headlamp management ECU. This should be updated with diagbox and will fix the rotating headlamp issue.
Best regards
Dave
