does the capteur de proximité Distronic need to be covered DS7
under the grille in the middle?
Ma DS Automobiles 7 Crossback Calandre avant, capteur de proximité Distronic 9819733877
is missing?
Martin
is missing?
Martin
It should be covered this way because it’s designed for radar readings. It also protects the radar from rocks, for example.
Il doit être recouvert de cette manière car il est conçu pour les relevés radar. Cela protège également le radar des pierres, par exemple.
Ah thanks for that, I made a replacement froma plastic basket many gaps and a message came up on the screen which said "imminent collision " so I thought thta the radar hasd bounced back off the cover I made even though it had load of gaps in it,
The one on the internet (second Hand) is 69Euros and it looks solid but must be correct?
Martin
9819733877 is correct for DS7
OK
Thanks for your info
I’ll have to bite the bullet and spend 69euros from Ovoko web site
Martin
