When connected to the central diagnostic socket, the diagnostic tools enable the following operations to be performed :
- Reading and exclusion of fault codes
- Reading parameters
- Test of actuators and inputs
- Downloading and configuring of ECUs
The diagnostic socket is located behind the dashboard lower trim.
CAUTION : Observe the order when carrying out the following operations (Risk of breaking of the dashboard lower trim guides) .
Insert the dashboard lower trim lower guides in their locations.
Tilt the dashboard lower trim upwards.
Reclip the dashboard lower trim .
|Pin number|Allocation of tracks of connector|
|1|Ignition positive|
|2|Track not connected|
|3|Line CAN DIAG High|
|4|Body earth|
|5|Electronic earth|
|6|Line CAN IS High ISO bus|
|7|Line K diagnosis (Engine management - Automatic gearbox - Additional heating)|
|8|Line CAN DIAG Low|
|9|Track not connected|
|10|Track not connected|
|11|Track not connected|
|12|Line K4 diagnosis (Stability control - Hydraulic suspension)|
|13|Line K diagnosis - BCM|
|14|Line CAN IS Low ISO bus|
|15|Track not connected|
|16|Battery +|
