What are your thoughts about using the regenerative B driving mode?
Personally, I never use it because I’m used to coasting a lot, and as far as I understand the regular brake pedal also regenerates power anyway when you use it.
So my thinking is, yes, B-mode might generate slightly more power perhaps, but you need to keep the gaspedal down for a longer time approaching an intersection anyway (instead of coasting and “save” power), using up more power before it starts to regenerate.
Could B-mode still be more effective and perhaps I should start using it (and ultimately gain some mileage)?
Another downside idea I have about B-mode are the brake pads.
Some years ago I had a C4 diesel with “automated manual gears”, which wasn’t a proper automatic but a manual gearbox that you didn’t have to select gears yourself.
This meant that it didn’t have any coasting when you let off the gas pedal. It behaved like a manual car and started to engine brake immediately.
This caused the brake pads to rust and get worn unevenly, because they were used so little, and I nearly failed the DMV test because of this.
Could the B-mode have a similar effect and lead to the decline of the brake pads?
Lets discuss. ![]()
