DS 3 CROSSBACK E-TENSE Range Increase
DS Automobiles has updated the electric powertrain in the DS 3 Crossback E-Tense to improve the car’s range.
The compact SUV can now cover 212 miles between charges, according to the WLTP test.
It represents a boost of 7% over the existing car.
During its development, DS says priority was given to the real-life usage of the car. Notably, the heat pump has been developed with a moisture sensor for increased efficiency.
Offered as standard, the heat pump enables heat to be produced by compression to generate hot air. As a result, energy consumption is reduced.
The car’s gear ratio has also been altered and new tyres, developed by Continental, are fitted. The EcoContact 6 Q introduces a new compound with high silica technology to improve rolling resistance and reduce noise emissions.
Similar updates have been applied to the Citroen e-C4, which shares a powertrain with the DS 3.
