How I can cansel start and stop function when I like do it
Welcome @K3V
It’s configured on the ADAS touchscreen. There’s no other option, and it must be configured every time the ICE is started.
To point it out, this is a regulation from the EU
Start and stop can be frustrating but it is proven multible time sthat it not only saves fule but a lot of saftey features that work in cars have reduced deadly crashes by more than 80% since there implementation it is actually extremely good that we have so many regulations even if it IS really frustrating from time to time.
I believe you should be able to set the ADAS button (the ‘car icon’ button next to the start stop button) as a shortcut to enable/disable start-stop by holding it for a second or two. If you press the ADAS button normally you will go to the ADAS settings on the touchscreen, and on the left you should have a button to set up the shortcut as you please.
I believe, that in DS 4 2023 plug in hybrid people can’t cancel star and stop, becouse of it starts always in electric mode and You even can’t noutice sarting. Thank’s anyway.
Thank’s Andrew! I believe You are right.
Sorry, I pressed something and the post got deleted. The S&S off solution in e-tense is sport mode.
Yes thanks, I red Your message and understod, that question was of S/S.
