Accessing Engineering Mode
You can access the IVI (Infotainment Touchscreen) Engineering Mode by performing the below steps.
Press and hold the multifunction touchscreen with 3 fingers until the keypad appears.
Enter the code
1232020 -
Press the
button.
Creating Logs
You can create logs by following the below steps.
Press and hold for more than 4 seconds with two fingers on the multifunction touch screen
or
Press and hold the
(Drive) key for 4-5 seconds
or
Press and hold the “Menu” key for 4-5 seconds
or
Press and hold the Volume + button for 4 seconds, but less than 7 seconds -
An audible beep may be heard when the log has been created.
Enter the engineering menu.
Select ‘Logging’.
Select ‘Head-Unit Log(s) List’
logs can then be deleted, sent to USB or sent to PSA/Stellantis servers.
Reading Version of IVI and BSRF (Radio)
- Enter engineering menu.
- Select ‘System’.
- Choose version to read.
- The version information is displayed.
