Here is soft and maps for NAC Wave2. You’re only interested in the EUR versions. Don’t try others.
But there will be problems, because your version is very archaic. But of course I could be wrong and everything will be ok.
Hi Alex
Thanks for the add.
I too have a DS5 Prestige 2015. The infortainment system works fine except for the maps section. I stupidly reset my system to factory settings (I know, I know!) and the map is now a vey old basic one. I’d like to update the map to something as good or better than the one I had but the updates from DS and Citroën are apparently too new and not compatible with the hardware that I have. I think that the a map-only update might suffice. Apparently the system is a SMEG+I v2 (???). I can let you have the VIN if you like. [VIN CENSORED]. Many thanks
I forgot to mention that I use a Mac for my computer and that I would appreciate any link from where I might download this now outdated software.
Many thanks
Downloaded appropriate files from DS website. They both failed. The firmware says that the software and hardware are not compatible; the maps (when trying to upload separately) failed half-way through. Consequently all date for maps has been overwritten it would seem. I am now left with no navigation system. Took are to Citroën - they are useless. Said their computers not compatible with DS cars. Strange as that is where my car is serviced. Now trying to get some help from DS itself.
Hello, I am using this Thread as it relates to my issue as well
I have DS5 that I need to update my firmware and maps and both applications do not approve or let me download.
My VIN is [VIN CENSORED]
smeg 6.1.D.R8
CD 30468
DATED: 11-09-15
Map version DbDw_37/Gr_410
Will appriciate the download the firmware and maps update (instructions can help also…)
This software version is fine. A newer one doesn’t add anything if everything is working.
Check the map version in the navigation system, not the main system. The number you provided doesn’t help.
The latest known map versions are v120 for Western Europe and v119 for the rest of Europe.
Hello Andrew,
Thank you for your reply.
Can you please let me know, or link me to how to check in the Nav system please?
I tried to check but could not locate another option.
Also, another questions, in the current system, I have the SMEG 6.1 that supports Apple CarPlay, but I have android and I cannot find Android Auto. Only another generic option “Mirror Link”.
Can this be added (Android Auto)?
Thank you in advance,
The SMEG system did not include an Android Auto option, and it cannot be added via software alone; additional hardware is required.
For SMEG you must have installed something like that. https://aliexpress.com/item/1005011591536189.html
Thanks Andrew!
Got it about the Android Auto.
Can you kindly let me know how to check the map version in the car?
Hi, I think I found it,
Map Italy v 106.1 (476.6mb)
Is this the information?
Yes, I should add that the latest one is number 120.
But maps files aren’t everything; a DMR code is also required, which is generated for each map version and tied to a specific VIN.
Maybe there is some information here: https://www.peugeotforums.com/threads/smeg-map-and-speed-camera-update-procedure.168681/#replies
Hi Andrew
Thanks for your help, will try in few days…(busy)
Uriel
does anyone have the Citreon DS5 2013 Map update for the UK, there’s roads on my map that aren’t updated and would be nice to get the updated version on a USB
Only UK, last official 2022
http://psa.download.navigation.com/automotive/PSA/RT6-SMEGx/M49RG20-Q0123-1181.ZIP
thank you, my SW Version is RNEG2.70.E.3 would it work with this or would i have to update my Software?
It’s ok. It’s better to leave it as is, because an update could cause an echo during Bluetooth calls—and that’s a major issue to resolve.
thank you
Hope someone can help 3 questions
Amy help gratefully received newbie to this
Welcome @Paul_Darragh
Do you have a touchscreen? What year is your DS from?
Thank you, it has a touch screen and is a 2016 model have tried the DS app links and they dont seem to work says corrupt file
That’s because you have old certificates, so that can happen. There is no simple fix for it.
As for Android Auto, the only options are swapping the SMEG unit for a NAC unit from a newer DS5 (2017>) or buying something like this.
