Ds3 1.6 hdi starter motor replacement
Trying to remove the starter motor on this model, from underneath the car if you remove the driveshaft you just about have enough access to the lower mounting bolt and terminals, is there an easier way to replace it? Someone suggested removing the exhaust manifold for full access?
