DS4 front door panel dissasembly
DS4 front door dissasembly instructions:
  1. First You need to take off the “soft” part, then the whole panel:
    1
  2. Unscrew the screws that are placed around the door panel, one screw on the bottom of the panel is visible, two screws are hidden:
  3. Pull the panel in the place pointed by the circle to take off the panel in picture below:
  4. Unscrew the screws to loose the main door panel;
  5. Take off the door handle:
  6. Pull the door panel to take it off, take a look where the clips are:
Door without the panel:
Hello, great post, thank you.
Do you know any solution about the noise coming from front door in my uploaded video?
From which part is it coming do you think? how can i solve it, do you have any idea?
I would say that its your door handle - does it work ok? - lower your window and take a look.
There is nothing else there - in the door.
When I pull soft part it stops.
But i’m not sure if it is related with soft part or main door behind the soft part :frowning:
I Think i can’t remove whole door as in your screenshots
Noise is very strange it sounds like something is vibrating but there is not much to vibrate.
Take the soft part out and check then, there is instruction in forum how to do this.
You have to unscrew two screws near the B pillar and pull the panel - only the soft part with leather.
Then it will be easier to check if it’s coming actually from the door.
Check locking mechanism especially the one on the body maybe it’s loose.
Try to knock the door trim a bit in different places, maybe You will hear something.
One other thing, inside the door panel when You take off the soft part there are 3 bigger screws that hold the whole door trim, maybe one of them is loose and that may actually give You that noise.
Two screws are located near the place when You recorded the wideo.
OK i will try and let you know the result. Thank you very much.
I think i solved it. I firstly realised that noise disappears after i unscrew the screws of soft part. Then, there is a detachable white screw hole. I removed it, wrapped it with cotton tape and put it back and screw again. Now there is no noise. I hope it will not come back :slight_smile:
Can anyone give me advice on the best place to start removing the main door card. I’ve removed the ‘soft” part and removed all the screws.
I assume at the bottom of the door card is the best, but any advice welcome.
Start from the bottom but take a look at pictures above, You have every screw and clip there :slight_smile:
Remember about the screw at the bottom!
Great photos.
Quick question,
After removing the door card have you ever got access to the rear of the door main handle
can i ask to get a rear door panel removing inctruction?
Hello,
Are there only 2 screws to remove soft part?
I unscrewed them but it’s still so tight to remove the soft part. May i brake something? :slight_smile:
Yep, two hidden.
Yep, but ussualy not.
