Ds7 ambient light
Hi, I just purchased a DS7 in the Opera version. I noticed from the menu that I can set the ambient lights on the sides of the doors and adjust the intensity. but they don’t work. I wanted to ask if it is a standard accessory and therefore perhaps it needs to be replaced. Thank you
Have you verified that they don’t work when the car is in night mode (i.e. when it’s dark outside, or when in a tunnel or a dark garage)?
Yes, I tried it and they don’t even turn on at night. from the menu are set to on. and maximum intensity
The graphic on the screen is incorrect. It is showing that the lights are in the black curved surfaces, when in fact the lights are in the door handle well (at the top).
Also after you’ve selected your preferred colour , if you switch to Sport Mode the lights will change to red along with the dash, it will go back to your preferred colour when you come back out of Sport Mode.
Dont expect them to be a dazzling display, they’re okish, they are more of a soft light at the top of the door in the handle that you pull on to close the door, (as already mentioned).
