DS7 power steering sound
Hello,
Ds7 2020my, 2.0hdi, i have noticed sound when vehicle is stationary and moving steering wheel left or right. Sound is similar to the sound that can be heard while driving on special surfaces in parking garages, and only can be heard when vehicle is stationary or driving bellow 5-10km/h…
my first impression was that I need to add power steering fluid, but DS have electric power steering.
Do i have a reason to be worried? Any advice?
Hello, I have too a 2020 ds7 crossback BlueHdi 180 of 2020 with literally the same issue. They thought in the mechanic that the issue was the car suspension cups, bit once replaced the problem persisted.
They said the issue is with the electric steering and it needs to be all replaced (2600€ new…). I am trying to figure out another solution for this, to see if there is a more reasonable and affordable way of fixing it
I would also need to add to my previous answer that this sound dissapears with cold weather and will only sound when temperatures are higher
Hi there
I have the same sound as all of you guys. I replaced inner tie rod and track rod end on both sides of my steering. This sound that you have all been hearing was in my case from this parts. As they are relatively cheap this was my first thought to do. You ne to do the alignment of your steering afterwards.
Br.
Hi, thank you for your answers. I hope so that rods can solve this issue.
I will change these parts after summer holidays and i will report resulrs here.
Same here…I was last week on seaside and temperatures were high… last few days I am on mountain, with temperatures around 15c sound disappeared
I have the same problem. Thanks for all the informations
This looks like the steering system is overheating. Monitor it at lower temperatures. You can also read faults in the steering, as it has its own controller.
Absolutely the same problem with mine also, during the summer the noise is there, during colder months nothing, one workshop recommended aligning the wheels, but I don’t think that has anything to do with the issue at hand. Did any of you guys try changing what @Lumpa2013 recommended?
Br.
