Does anyone else have problems with the tire pressure warning system? The car is a DS7 E-Tense 4x4 Crossback 2019. Especially in this cold weather, the car tells me about once a week to check the tire pressure. And when I go to check the tire pressure, everything is fine. As far as I know, the system works by measuring the differences in tire rotation speed.
If the tire pressure is OK, reset the pressure reading.
Pressure differences can occur with large fluctuations in outside temperature. Especially if you drive on one type of tire all year round.
The manual states that tire pressure should be measured when the tires are cold. Otherwise, after driving for 10 minutes or after driving 10 km at a speed above 50 km/h, you should add 0.3 bar to the pressure indicated on the sticker.
