Interior lighting
Hi all
Does anyone know how to turn on the interior/courtesy lighting on the new DS4 e-tense? It says off on the control panel in the roof above the interior mirror, but I can’t find where the control/switch is.
Hi @RevinKevin
The courtesy lights are touch sensitive with the sensor at the end closest to the windscreen to turn on. Touching the middle light at the back end should turn all the lights off if you are using all 3
If you touch and hold where it says ‘off’ for 3 seconds, it will enable the courtesy lighting.
