Intermittent electrical fault
To any and all DS9 owners, have you had the same issue with your 2021 DS9. Now its started in the cold mornings the issue has returned. When i get into the car and start up the radio sound does not come on as usual and the passenger chair electrics stop working as well as the rear electric seats and the electric boot. So must be all wired into the same loom. - but what can i do to fix the issue. The colder it becomes the longer the issue persists during the drive… up to not working at all. Driving me bonkers to pardon the punn. Any advice welcome
Hi! Quite a few electrical issues can be related to a weak or failing 12V battery, especially considering what you mentioned about the problem getting worse in colder weather. Have you noticed any warning messages or errors on the dashboard? Also, when you start the car, do you ever get the “Energy Economy Mode Activated” message? It could be that the battery is no longer holding its charge properly, which might explain why some electrical systems stop working, particularly in cold weather.
Also, do you have any way to scan the car for fault codes? I would probably start by checking the battery’s condition and voltage before looking into more complicated electrical issues.
The shared symptom across radio, seats and boot points more to supply/earth than separate faults. A resting voltage test and a load test are worth doing, but also check the battery terminals, main earth straps and the underbonnet fuse/relay box for corrosion or loose connections. Cold makes marginal joints and a weak battery worse. If you can get fault codes read, note any low-voltage or communication codes rather than just clearing them.
