Hi DS Community. My front passenger side door doesn’t open or close using the keyless entry. All other doors and boot work as they should but not that door? Any ideas? Thanks in advance.
Welcome @Molson !
Yep, I got an idea… it’s broke.
My driver door lock didn’t work when I got the car so I had to replace it.
Been working fine since.
I got another idea.
The keyless entry feature is cr*p.
DS have been trying to get mine to work correctly for the last 7 months.
Latest update from their technical department is “We know there are some owners experiencing issues with keyless entry & welcome lights, we are working on a software fix, and an update will be released in due course”.
This was emailed to me a few weeks ago, after countless visits to the dealership, countless other updates, 2 new keys, 2 new 12v batteries, 1 new modulator, 2 visits from a Technical UK head technician to work on the car , and 175 miles put on the car by their technician because they thought the short journeys weren’t helping.
7 months on nothing has changed.
My RHD DS7 did that, not ALL the time but enough to be irritating. Prob a lubrication issue but knowing how cr*p many dealers in UK are don’t hd your breath.
Gen found dealers in France cheaper and more competant
Thanks for the reply’s. I’ll give the lubrication a try (lock/hinges/handle etc). It’s got two chances🤞
Did you get the solution?
This will most likely turn out to be the known issue of water ingress into the handle mechanism, which is supposed to be a sealed unit.
Clearly the proximity feature (Keyless entry), is working as the other 3 doors unlock, so the door thats not working has an issue with the handle.
Lubricating through the handle wont solve anything, at least not long term.
You need to read the other posts on here regarding exact same fault.
Two options.
- New handle & mechanism assembly.
- Remove the inner door panel, open up the handle sealed unit, clean out, put back together re-seal. This option will save you around £300 for a new handle.
Theres posts on here showing how to get to the handle.
BTW, the keyless entry does have known issues, but it would effect all 4 handles if that was you problem.
@Jactac don’t compare your experiences with the door handles on the DS4 to those on the DS7. That’s a completely different matter.
In the DS7, you need to check the antenna in the passenger door handle or, as a first step, simply read the error codes with Diagbox.
