Hello,
I’m the proud owner of a 2024 DS4 plugin hybride Rivoli 225
When I accelerate there is a creaking sound on the left, the same noise when I brake, it’s not loud but it’s annoying, the dealer says that it’s “normal” a problem that all ds4 have, is it normal? Anyone else have this problem to?
Welcome @Phoog2022
This isn’t normal. Sometimes (rarely) it creaks when turning the steering wheel while stationary, but it depends on the outside temperature.
Do you also hear it when going over things like a speedbump? I’m thinking towards the adaptive suspension stiffening and loosening or something.
I’ve had creaks as well somewhere in the first year of my ownership, turned out there were little pebbles lodged in between the suspension…
Yes, the creak appears when I drive over a speed bump, the dealer says “It’s the operation of the front suspension/axle you’re hearing.”
I’m having a hard time believing this.
This is too much. There’s a problem, you just have to find it.
Its the shock absorber, not the shock itself but the top mount of shock absorber, i had that on my peugeot 308 2014 and after replacing whole shocks asembly it run like new
Oke no worry’s for me, I have still factory warranty
Your dealer is not being very helpful. If it still has warranty be firm and demand they put it right. If they still dont want to help contact DS Customer services. They dont roll of the production line with that problem.
The dealer replaced the support arm rubbers.
The noise is gone!
Thank you all for responding
