Problems with the firmware update (incompatible version & possibly expired certificate)
Hello Community,
I’m a big fan of French cars, especially my DS 7 Crossback! However, I’m stuck with a frustrating issue and really hope someone can help me out.
I want to update my system’s firmware from 31.09.46.62_NAC-r0 to 42.03.33.42_NAC-r0 via a USB stick.
I followed all the instructions using the DS Update App and prepared the USB stick correctly (I even tried 5 different USB sticks).
What I’ve tried so far:
  1. Deleted the license file and connected my DS to a hotspot.
  2. Disabled Bluetooth on my phone.
  3. Followed every guide I could find in various forums.
Despite all this, the update never works. The system keeps showing the message:
“Version not compatible with hardware.”
Could the certificate have expired?
Someone mentioned that the certificate might have expired, which could cause this issue.
But how is that possible if everything was done via the DS Update App?
If the certificate is indeed the problem, how can I check it and get a new one?
My Questions:
  1. Has anyone else faced this issue?
  2. How can I confirm if the certificate has expired, and how can it be renewed?
  3. What else can I try to make the update work?
I really want this update to improve my system, and I’m getting frustrated that it’s not working despite following all the instructions.
Please, I need your advice! :pray:
Thanks in advance for your support!
Hi @Kenan_Artiran,
Could you try downloading the 42.01.72.32_NAC-r0 WAVE3 firmware below?
It is the firmware between your current and the latest.
https://majestic-web.mpsa.com/nas/eu/mjb00/NAC_EU/ovip-int-firmware-version/PSA_ovip-int-firmware-version_42-01-72-32_NAC-r0_NAC_EUR_WAVE3.tar
Pop this on your USB with the license.
Hi Alex,
yes I tried also that. The same…
Nobody can help me.
Best
Kenan
Just curious, why are you trying to update? Is there something specific you are having problems with? The updates don’t contain anything new, just internal bug fixes which rarely affect usability.
If you are trying to update maps, then that is a separate issue.
Hello,
I have exactly the same problem.
It’s not because the firmware has a bug that I want to update… it’s because the installed map is a version 9 and you can’t put a more recent map if you don’t update the firmware.
The update is a batch that includes the firmware and the 10 map.
Welcome to the community, @thoun !
Thank you for that!
So always update system before map. :+1:
Hay algun enlace que contenga solo la actualizazion de la pantalla?
Same Issue for me :
  • same install FM
  • same targeted FM
  • same error message…
Hi the users having issues updating have hardware version “wave 3” unfortunately DS are not signing the license file to authorise updating the mapping or system version. So unless we wait for this issue to be fixed (likely with a new update) we can replace the existing NAC with a wave 4 hardware and software. @magpieautos can help with this if someone really does need to run the newest hardware / mapping.
same problem here with ds9; downloaded software update and maps but with both (together or independent) get message; Version not compatible with hardware. So it there still no solution for this problem??
