Radio stops working when braking
Hi
I’ve got a problem with my ds4 where the radio stops working when i press the brake pedal. I’ve replaced brake switch as thought it may be short circuiting but no luck.
Hey Joel,
I had something similar with my Citroen C3 but it was my indicators that turned the radio off. Turns out it was because I had fitted LED lights, and that was causing interference with DAB.
ah OK I have not ever changed the bulbs ever but I’ll check to see if they’re leds
