Hi All, does anyone have an idea or manual how to remove the plastic from the tail gate? I want to install a dashcam and I want to hide the cables. thanks for advice
Hi
I have recently do the same job. I found the best way for for me was to just poke the wire into the plastic; if however you want to remove the plastic then using the tool that came with the dash cam; carefully insert the tool into the plastic and click it out.
