“a” Zero reset switch for the function selected (Service indicator or trip meter).
Maintenance indicator reset procedure (By means of the wipers stalk zero reset switch) :
- Switch off the ignition
- Press and hold the wipers stalk zero reset switch (at “a”)
- Switch on the ignition : The distance recorder display begins a countdown
- When the display indicates “=0” : Release the button ; The spanner symbol disappears
