Reverse mirror tilt
Hi all, anyone know how to set the mirror reverse tilt angle? Mine isn’t tilting enough. I’ve tried selecting reverse, set mirrors to where i’d like, press M and then 1 on memory seat, it does not give sound of confirmation! The mirrors return to normal after selecting N or D but reverse just tilts so far again, not where I want. Does anyone have any idea? Even other makes models of car must be similar and use the same procedure? Thanks.
Briefly press the M button and release it. Then, within 1-2 seconds, press and hold 1 or 2 until you hear a sound.
Thanks Andrew, I’m afraid that doesn’t work. It will store my seat position if I change it with a sound of confirmation, but the mirrors will not change or any sound when trying. Any other suggestions welcome.
There’s a general problem with these procedures. My DS4 only remembers the position when I press and hold M and then 1 or 2 (still holding M). This contradicts the user manual.
Tried that too, still no go, what did happen is the brm clock turned 24 hrs when I started up! Strewth…
