Screen interface update
hello, I have 2022 ds 225 hp, I bought the car in November, but it got old very quickly, screen interfaces, climate controls and many at least screen interfaces can not be updated like 2023 ds
Hey Arif,
Welcome to the community!
The DS7 (notice that CROSSBACK was dropped from it’s name) was announced back in June 2022, however if you already had an order in for the DS 7 CROSSBACK then you would receive that - they are two different models :slight_smile:
You are right, but there were vehicle features and it was not said that there would be such a change.
Yes because it is a rebranded vehicle, the changes were announced in June 2022. The DS 7 is a different car to the DS7 CROSSBACK, it has different front and rear styling, upgraded infotainment, 360 cameras, new colour options amongst other things - it would be unfair for them to just change what you ordered and give you the DS7 instead - maybe you wanted the CROSSBACK version.
I don’t have a request for a new vehicle anyway, I just asked if the multimedia screen can be made and updated.
Yes it would be possible to update the touchscreen and driver display - however they need to be programmed to your vehicle using special software. It’s not something a dealership would do for you, it needs to be done by a specialist. Where abouts are you located in the world?
I live in Turkey
I would look on some Turkish Peugeot/Citroen forums and see if there is anyone who has knowledge of telecoding. As well as purchasing the new parts they would need telecoding in to the BSI and various other ECUs.
Hi Alex,
I bought the DS7 Crossback 2019 (diesel 2.0, Rivoli), and I have a problem regarding the multimedia system update. On the app, it says that I need to update it with 42.03.33.42_NAC-r0. I tried 3 different USBs, and none of them worked. I downloaded the file that you posted here, but still nothing. It says: No media content on the USB memory stick. Or I even got the message: It is not supported by hardware. Also, I would like to update the maps, as they are old (2018). When I put music on USB, everything is working normally. Also, my current system is next: 31.09.46.62_NAC-r0
Dated: 2018-11-17
Can you please help me?
Thanks in advance.
A mi me pasa lo mismo, archivos bajados desde el ordenador con windows update y desde los enlacen mandados por atencion al cliente, 4usb y en todos el mismo mensaje sofware no compatible con hardware
Mod edit (translated):
The same thing happens to me, files downloaded from the computer with Windows Update and from links sent by customer service, 4usb and all the same message software not compatible with hardware
Me acaban de llamar de atencion al cliente y dicen que es problema de la actualizacion, que ya no me aparecera en el programa hasta que manden otra, me parece que ya no voy a poder actualizarlo mas
What do you mean? So, will we not be able to update the software from now on?
Según ellos esta versión Cartografía + Software de pantalla táctil (42.03.33.42_ NAC-rO) es la que han retirado por fallos y que ya sacaran otra, pero no saben cuando
Can we download any older versions? Mine is from 2018, and I want to update it, even with 2023.
No se igual alguien puede mandar algun enlace de descarga anterior , el mio tambien es del del 2019
Ahora no me aparece ninguna actualizacion nindesde la app ni desde el ordenador alguien sabe algo?
Despues de muchos intentos al fin he podido actualizar tanto la pantalla como los mapas por separado desde la pagina
