Hi, does DS7 crossback 1.5 diesel 2020 have timing chain or belt?
Hi,Engine DV5RC BlueHDI 130hp. Timing belt.
Timing belt.
It has both. There’s a chain between the camshafts, and a belt drives it from the crankshaft. The service campaign is for the chain. They are changing from 7mm to 8mm, along with the camshafts and cover. Timing belt replacement is available at an additional cost.
