Vehicle Height set up
Hi everyone!
Can someone help me with the procedure to adjust the active suspension, it seems like the headlights are going to adjust by the same 4 sensors fitted on the wheels.
I did a rear height modification of the height in the Lexia, and now the headlights are maximum up😀.
As described in Lexia I need to input the distance from the rear sensor member to the ground and wheel radius .
A default values will be also welcome :grin:.
Thank you all for your interest in helping on this matter.
Not sure this will be of any help, or just an insight.
My Last car, Citroën C5 (X7), when setting the height you had to find the middle of the axle, then take the height from the ground to a checking pad (on both front & rear Sub-frames) and if this figure was within the given tolerance, then Okay. If it wasn’t, the sensor clamp on the anti-roll bar had to be adjusted, being very aware than 1 degree of rotation could up to 20-30 change of height.
I’m not sure of the DS set-up but I would imagine the theory would be very similar.
Good luck
Thank you for the response,
It is relatively simple ,just needed to measure the distance under body as I found for 508, and give the inputs…for anyone interested they can see the pictures attached.
Case closed for me. Job done !:pray::grinning:
Similar but much much better, its amazing how things change over 16 years!!
Well Done.
