Had my totally new car for two weeks now covering roughly 2000km.
Last Friday it started firing intermittent warnings for the rear brake light at startup.
During Sunday it advanced to raising a warning for bra system malfunction, still only at startup.
Thought that I would record the fault and send it to my workshop. Took my phone, started recording and pushed “Start”… No fault!? Did the same thing over and over again without being able to replicate the fault while recording.
Gave up and thought that it only was a glitch.
Yesterday I got the fault directly when I started the car, turned car off and started again while recording. No fault!!!
Turned the car off, connected my USB cable for charging and started the car again - Error right away…
At that moment I started thinking of when I brought my USB cable to my car… Last Friday… And every time I was going to record the fault I removed the charging cable ![]()
At the evening I tried again without phone connected - no error, with phone connected - error.
I guess that my phone uses so much power when charging that it messes with the sensitive CAN system.
Do you guys have any other ideas?
Note. It doesn’t actually have any faults with neither brake light or system, fault message disappears after a few seconds and everything works as it should.
