My drivers window will only lower about 75% then stops. The only way to raise the window is by operating the switch and physically lifting the window. Is there a way to reset the window please.
Perhaps this could be what you seek.
https://dsforums.net/t/programming-of-side-windows-min-and-max-position/654?u=dsjay
Thanks for your advice. I tried both methods and neither worked. My window switch stopped working completely for a short time but then started working again but still not operating window correctly.
Hopefully I can get it sorted uner warranty. Coincidentallythe drivers door keyless lock/unlock has also stopped working.
Yeah, I had that problem too after buying my DS7 a year ago.
Had to let the shop fix it for 500 eur. No warranty left.
Seems like a common problem with these cars.
