DS4 rear door panel dissasembly
  1. First take off soft panel which is placed in the green area:
    2
  2. Do it by first unscrewing the screws located on both sides of the door trim and at the bottom - take a good look:
    1
  3. Unscrew other screws and take off the handle:
    3
  4. Take a look at the clips location to take off the panel:
    4
Door without the panel:
Excellent posts. Hopefully they will help people in the future wanting to upgrade audio!
Hello, great post, thank you.
One question here, after unscrewing the screws, should we use force to remove the panel? Is there any risk to break the clips or is it easy to remove it after unscrew operation?
Thanksss
And is front door removal the same?
Front door panel disassembly is also posted in the forum.
If You unscrew everything panel goes off rather lightly however You have to pull to get those clips off.
Some of them may brake - it’s plastic so You know…
Start loosing clips from the bottom.
Remember to unscrew everything.
whats the link for front door? Appriciate if you have it. Thanks
