Fuses
Hi looking to install my dashcam into my 2022 ds4 how do i access fuses plus find a fuse diagram so i can work out whicj fuse to use thanks
I tried to do the same, found plenty of diagrams o on the net and which fuse to use. That was the easy part! I removed the fuse box cover but by the time I did all that I quickly realised that to get access to the fuses I would need triple jointed fingers which can only be about 1 8 th thick ! I gave up and just used the cigar power point in the small compartment in the front. It’s not ideal because the power only works with the ignition on but I couldn’t do any better. I think because the car is designed to be left hand drive the fuse box had to be shifted and that was the only place to put it. I’d be very interested if you achieve access and wish you luck
Sorry I should have said mine is a ds7 so hopefully yours is different
Thanks buddy cant find any pics of fuses mine might be similar to yours will persevere with it lol
Anyone has the diagram for the whole fuse box for 2023 ? Ds4 cross ? I need to chcecj fuses and there is nothing everywhere
I recommend this thread Fuse for hardwiring dashcam
